[vcf-midatlantic] LSI-11 simulator (looking for the author)
Kenneth Gober
kgober at gmail.com
Fri Sep 11 13:09:00 EDT 2020
On Thu, Sep 10, 2020 at 2:50 PM Richard Cini <rich.cini at gmail.com> wrote:
> I might have found it.
> AA-PE7VA-TC_RT-11_Device_Handlers_Manual_Aug91. Appendix A has a sample
> DX/DY handler which is for the RX01/RX02. Not sure what a “PF” device is or
> how it relates to DX/DY.
> It still seems that the RX11 code within the simulator would need changes
> to support native disks.
That is the correct document. The DX and DY handlers are presented as a
model for how to write a device driver for a new type of disk device not
already supported by RT-11. In this case the PF device.
I took a more detailed look at the code (I still don't have a platform
ready-at-hand that it compiles on) and it looks like the disk code in the
simulator isn't pretending to be an RX11 after all, or any other real DEC
disk device. Rather it is an entirely made-up device designed to be easy
to implement in the simulator, and also easy to write a device driver for.
For example, it appears that the PF device works purely at the block level
so you don't need to worry about tracks and sectors. This makes writing a
custom driver from scratch easier, but ironically it also makes it harder
to do this starting with an existing device that already has track/sector
code.
It may be easier to add real RX11/RXV11 support to the simulator than it
would be to write a new RT-11 driver for the PF device, since the latter
requires you to already have a running RT-11 system (or similar) to do the
development work on. It's a question of how much effort you want to put
into this when there are other emulators that work already (e.g. simh,
ersatz-11, etc.). Or more to the point, which would you find more
fun/interesting? Writing a new RT-11 PF device driver (or rewriting one
that was previously written and is now lost) in PDP-11 assembly, or writing
an RX11/RXV11 simulator in C?
-ken
