[vcf-midatlantic] Mac SE PRAM battery - replace with a holder
Richard Cini
rich.cini at gmail.com
Mon Sep 14 20:17:40 EDT 2020
FYI, with a standard holder, it won’t clear the metal cage properly so I just went with the axial-lead battery. Works great and the SE lives. A lower-profile holder may work. The pins are properly spaced.
Not I need to back up stuff on it. Maybe a few megs at most. Will probably use diskettes, but I may also try Terminal and a null modem to my PC (my latest favorite transfer method).
http://www.classiccmp.org/cini
Long Island S100 User’s Group
Get Outlook<https://aka.ms/qtex0l> for iOS
________________________________
Sent: Monday, September 14, 2020 7:09:47 PM
To: vcf-midatlantic <vcf-midatlantic at lists.vcfed.org>
Subject: Mac SE PRAM battery - replace with a holder
I just dug out my old Mac SE to check the battery and it needs replacing. In the SE, it’s soldered to the motherboard.
I have replacements, both with leads (the original) and without (to be used with a holder). Other than not being original, any concerns or pitfalls with this approach?
I couldn’t think of any but I thought I’d throw it to the group. I still need to check the clearance on the cage, though.
Rich
