[vcf-midatlantic] Moving files from an old 68k-Mac to an emulator or other machine
Herb Johnson
hjohnson at retrotechnology.info
Thu Sep 17 23:46:19 EDT 2020
Rich Cini says: have an old System 7 or 8 Mac, it put files on a Mac
format ZIP disk. Then run a recent-enough OSX (pre 10.15) Mac that can
read the ZIP disk via a USB ZIP drive.
OK, got that. But I got lost when Rich said "use an emulator to get the
files into the emulation environment".
Rich, were/are you trying to copy files onto some modern computer, to
make use of them with modern software? Or ... copy files ... to *run*
them under some emulation of say Mac System 7? Or, both?
People ask me about such things often enough. It would be good if I can
tell them what they may be able to do. Most people won't want to run an
emulator, they just want to migrate old files or at least archive it. I
always warn them of the problem of old programs that make files, that
new programs can't read (even if you "copy" them over to the new computer).
regards, Herb
or try later herbjohnson AT retrotechnology DOT info
