[vcf-midatlantic] Moving files from an old 68k-Mac to an emulator or other machine
Richard Cini
rich.cini at gmail.com
Fri Sep 18 08:04:56 EDT 2020
Herb -
The backstory is that I wanted to bring a “Mac on a Stick” to my mom’s house and show her the old files and things from when she taught English at the middle school in her town (she’s long retired now). There’s a lot of interesting stuff she collected and some very creative things she did using PageMaker.
So, I created a vMac environment on a thumb drive that actually matched her system (MacSE, 100MB drive, all the same software). The original programs exist on-line (I have most of the disks too) but I needed the data.
But, you bring up an excellent point about data migration in general. I’ve done it a handful of times on individual files and it requires multiple machines running different versions of the program. For example, migrating a Word for Mac 1.0 document with formatting requires it being passed through at least two versions to get it “modern” enough to work. Or even like an old WordPerfect 5 doc on the PC. And that doesn’t even cover a file on an old S100 machine where there is a migration “dead end” like WordStar. Those you just need to find the “lowest common denominator” file and bring that over.
Rich
http://www.classiccmp.org/cini
Long Island S100 User’s Group
Get Outlook<https://aka.ms/qtex0l> for iOS
________________________________
From: vcf-midatlantic <vcf-midatlantic-bounces at lists.vcfed.org> on behalf of Herb Johnson via vcf-midatlantic <vcf-midatlantic at lists.vcfed.org>
Sent: Thursday, September 17, 2020 11:46:19 PM
To: vcf-midatlantic <vcf-midatlantic at lists.vcfed.org>
Cc: Herb Johnson <hjohnson at retrotechnology.info>
Subject: Re: [vcf-midatlantic] Moving files from an old 68k-Mac to an emulator or other machine
Rich Cini says: have an old System 7 or 8 Mac, it put files on a Mac
format ZIP disk. Then run a recent-enough OSX (pre 10.15) Mac that can
read the ZIP disk via a USB ZIP drive.
OK, got that. But I got lost when Rich said "use an emulator to get the
files into the emulation environment".
Rich, were/are you trying to copy files onto some modern computer, to
make use of them with modern software? Or ... copy files ... to *run*
them under some emulation of say Mac System 7? Or, both?
People ask me about such things often enough. It would be good if I can
tell them what they may be able to do. Most people won't want to run an
emulator, they just want to migrate old files or at least archive it. I
always warn them of the problem of old programs that make files, that
new programs can't read (even if you "copy" them over to the new computer).
regards, Herb
or try later herbjohnson AT retrotechnology DOT info
