[vcf-midatlantic] Moving files from an old 68k-Mac to an emulator or other machine
Alexander Jacocks
jjacocks at gmail.com
Fri Sep 18 13:20:54 EDT 2020
Maybe I’ve missed someone else mentioning it, but I strongly suggest BMOW’s
FloppyEMU, for archiving from vintage machines. That gives you disk images
that you can directly use, in emulators. Obviously, it requires an external
floppy port, to use easily, but you can connect one to an internal floppy
port, as a fallback.
I suspect everyone here is aware of this, but wanted to mention it.
- Alex
On Fri, Sep 18, 2020 at 10:27 Richard Cini via vcf-midatlantic <
> I was asking more about what the latest version of Debian that can run
> Nettalk 2.2 was.
> Rich
> Rich Cini
> http://www.classiccmp.org/cini
> http://www.classiccmp.org/altair32
> On 9/18/20, 10:00 AM, "vcf-midatlantic on behalf of Andrew Diller via
> vcf-midatlantic" <vcf-midatlantic-bounces at lists.vcfed.org on behalf of
> Are you are asking if there is a more recent Linux that will support
> netalk? Or are you asking if any recent OSX can access the netatalk shares
> in 2.x?
> I tend to think of AppleTalk on ethernet as Ethertalk, to disambiguate
> it from LocalTalk (which people may be using if they have a bridge).
> If you can keep everything on ethernet (i.e. you have a network card
> for all your macs so you can get them to a switch and a common network
> segment/subnet) I've found that even recent versions of OSX
> (10.10/Yosemite) can access a netatalk 2.x share via TCPIP and easily share
> files with older macs.
> The biggest issue is usually the form of the archive used and ensuring
> that the resource forks can be properly re-constructed. SIT files are the
> best to ensure this.
> I've also setup netatalk on a older laptop w/ Ubuntu 10.04 LTS (Lucid
> Lynx) and it works great for this transfer. being on an extra, older laptop
> I can just leave it till I need it again and even it's smallish HD is huge
> in comparison to the files for classic macs.
> -andy
> > On Sep 18, 2020, at 8:29 AM, Glenn Holmer via vcf-midatlantic <
> > From: Glenn Holmer <cenbe at kolabnow.com>
> > Subject: Re: [vcf-midatlantic] Moving files from an old 68k-Mac to
> > Date: September 18, 2020 at 8:29:51 AM EDT
> > To: vcf-midatlantic at lists.vcfed.org
> > On 9/17/20 6:13 PM, David Riley via vcf-midatlantic wrote:
> >> Actually, IMO, the best option is: if you can get an Ethernet card
> in
> >> the SE, you can run Netatalk 2.x on Linux or NetBSD (both still
> >> support AppleTalk, but netatalk 3.x does not).
> > I'm keeping an old version of Debian on a Raspberry Pi so I can run
> Netatalk 2.2 for my Mac SEs. Is there anything current that will support
> AppleTalk?
> > Glenn Holmer (Linux registered user #16682)
> > "After the vintage season came the aftermath -- and Cenbe."
