[vcf-midatlantic] Moving files from an old 68k-Mac to an emulator or other machine
Richard Cini
rich.cini at gmail.com
Fri Sep 18 13:41:46 EDT 2020
I use the SCSI2SD for my PDP-11/23+ system. I boot RT-11 from an Emulex SCSI card. Great product too.
http://www.classiccmp.org/cini
Long Island S100 User’s Group
Get Outlook<https://aka.ms/qtex0l> for iOS
________________________________
Sent: Friday, September 18, 2020 1:39:33 PM
To: vcf-midatlantic <vcf-midatlantic at lists.vcfed.org>
Cc: J. Alexander Jacocks <jjacocks at gmail.com>; Richard Cini <rich.cini at gmail.com>
Subject: Re: [vcf-midatlantic] Moving files from an old 68k-Mac to an emulator or other machine
The floppy EMU is cool definately worth picking one up (for the earliest macs), there is also this for faster transfers (for Mac's that have the 25pin scsi)...
https://store.inertialcomputing.com/product-p/scsi2sd-v5.5.htm
I will note - sometimes the SCSI can be bad/flakey on systems w/ leaking caps. The Floppy port however almost always works.
-andy
On Sep 18, 2020, at 1:35 PM, Richard Cini via vcf-midatlantic <vcf-midatlantic at lists.vcfed.org<mailto:vcf-midatlantic at lists.vcfed.org>> wrote:
I had no idea that existed. So it’s like a GoTek but for the Mac. Absolutely awesome. Thanks for sharing the name.
Rich
Sent: Friday, September 18, 2020 1:20:54 PM
Cc: Richard Cini <rich.cini at gmail.com>
Maybe I’ve missed someone else mentioning it, but I strongly suggest BMOW’s FloppyEMU, for archiving from vintage machines. That gives you disk images that you can directly use, in emulators. Obviously, it requires an external floppy port, to use easily, but you can connect one to an internal floppy port, as a fallback.
I suspect everyone here is aware of this, but wanted to mention it.
- Alex
