[vcf-midatlantic] Recapping a Mac IIci
Sentrytv
sentrytv at yahoo.com
Sat Sep 19 15:44:06 EDT 2020
I know this may not be ROHS compliant but:
Use standard 60/40 rosin core solder of the correct diamete.
basically a thin diameter.
It will melt faster and be easier work to with. especially smaller components.
I know I might get a little flak for this but it’s what I do and it’s older equipment.
Mike Rosen
Sent from:
My extremely complicated, hand held electronic device.
> On Sep 19, 2020, at 3:29 PM, Richard Cini via vcf-midatlantic <vcf-midatlantic at lists.vcfed.org> wrote:
> Ok, looks like it works...sort of. The soft power switch seems to keep turning the machine on, and the Radius 8-bit video card isn’t working with this board (not sure why). But, at least it’s running. I suspect there is an issue with the power switch itself on this board, and the positioning of it (the twist, horizontal or vertical) doesn’t seem to matter. I did swap power supplies and that has no effect.
> I’d still like to get the other board recapped and working again. If there is no real “service” for this any longer, I could do it again. It was just a little nerve wracking for me. I found that the solder Apple used doesn’t melt well with a regular iron and I would up lifting a pad getting a cap off.
> Rich
> http://www.classiccmp.org/cini
> Long Island S100 User’s Group
> Get Outlook<https://aka.ms/qtex0l> for iOS
> ________________________________
> From: Richard Cini <rich.cini at gmail.com>
> Sent: Saturday, September 19, 2020 2:56:08 PM
> To: vcf-midatlantic <vcf-midatlantic at lists.vcfed.org>
> Subject: Recapping a Mac IIci
> All —
> I have an Apple IIci main board that need recapping. Does anyone know of someone that does this? I bought a recapping kit and tried it on my spare machine and it doesn’t seem to work (I get the bing but no video; no explosion at least) but I’d rather not try it on the main machine.
> Thanks!
> Rich
