[vcf-midatlantic] Recapping a Mac IIci
Ethan O'Toole
telmnstr at 757.org
Mon Sep 21 10:23:48 EDT 2020
The problem is when the capacitors leak juice out it changes the chemistry
of the solder or something. Unsodering leaked caps is often a difficult
mess.
I don't know if the IIci uses surface mount caps or not. I haven't had one
in a long time (but wouldn't mind another one, they are cool. I was
eyeballing that one at Festivus or whatever.)
One thing you can do, clean it off as much as possible then try to add new
solder to the old solder first, then try to desolder it. Another trick is
cutting away the old cap first using snips, but this brings the risk of
pulling up traces.
Similar to the other poster, I always use leaded solder. I don't know
anyone that uses lead free at home.
On Sat, 19 Sep 2020, Sentrytv via vcf-midatlantic wrote:
[NON-Text Body part not included]
