[vcf-midatlantic] tantalum caps with a slit/cut down the middle
Bill Degnan
billdegnan at gmail.com
Fri Aug 6 00:43:15 UTC 2021
Thanks. Yes both boards that have the slits are old ethernet boards.
Bill
On Thu, Aug 5, 2021 at 8:36 PM Jonathan Chapman via vcf-midatlantic <
> They're probably actually ceramic, these are called "gap caps," and are
> often seen on Ethernet boards. They're used to provide a discharge path on
> things that may see spikes on external connections:
> https://www.vishay.com/docs/28521/gapkap.pdf
> If that's what they are, the gap is totally normal :)
> Thanks,
> Jonathan
> ‐‐‐‐‐‐‐ Original Message ‐‐‐‐‐‐‐
> On Thursday, August 5th, 2021 at 20:32, Bill Degnan via vcf-midatlantic <
> > I have a few boards with tant caps that have a thin slit down the middle
> of
> > them. Looks like this was done at the factory, not a tear or a blown cap.
> > early 90's.
> > Normal?
> > Bill
