[vcf-midatlantic] tantalum caps with a slit/cut down the middle
Gregg Levine
gregg.drwho8 at gmail.com
Fri Aug 6 02:24:30 UTC 2021
Hello!
Bill to what fraternity are these ethernet boards a member of?
Gregg C Levine gregg.drwho8 at gmail.com
"This signature fought the Time Wars, time and again."
On Thu, Aug 5, 2021 at 8:43 PM Bill Degnan via vcf-midatlantic
<vcf-midatlantic at lists.vcfed.org> wrote:
> Thanks. Yes both boards that have the slits are old ethernet boards.
> Bill
> On Thu, Aug 5, 2021 at 8:36 PM Jonathan Chapman via vcf-midatlantic <
> > They're probably actually ceramic, these are called "gap caps," and are
> > often seen on Ethernet boards. They're used to provide a discharge path on
> > things that may see spikes on external connections:
> > https://www.vishay.com/docs/28521/gapkap.pdf
> > If that's what they are, the gap is totally normal :)
> > Thanks,
> > Jonathan
> > ‐‐‐‐‐‐‐ Original Message ‐‐‐‐‐‐‐
> > On Thursday, August 5th, 2021 at 20:32, Bill Degnan via vcf-midatlantic <
> > > I have a few boards with tant caps that have a thin slit down the middle
> > of
> > > them. Looks like this was done at the factory, not a tear or a blown cap.
> > > early 90's.
> > > Normal?
> > > Bill
