[vcf-midatlantic] VCF Museum and Warehouse Update
Tony Bogan
tony.bogan at vcfed.org
Sun Aug 8 22:49:37 UTC 2021
Thanks Martin! I didn’t bother putting all the numbers on the one that I was going to post, I just put big letters “current VCF Museum” with a little tiny space, “ future VCF Museum” Showing a big gigantic space!
Tony
Sent from my iPhone
> On Aug 8, 2021, at 6:27 PM, Martin Flynn via vcf-midatlantic <vcf-midatlantic at lists.vcfed.org> wrote:
>> On 8/8/2021 6:04 PM, Martin Flynn via vcf-midatlantic wrote:
>>> On 8/8/2021 5:39 PM, Herb Johnson via vcf-midatlantic wrote:
>>> Others, who visit sporadically, do not know what they are talking about. I barely know myself, despite 15 years of my visits to "the campus" of Infoage, because I have a dyslexia about "names". So building 9010 versus 9010B versus 9999 versus 9009 all. look. the same. names. to. me.
>>> https://infoage.org/wp-content/uploads/2020/06/NHL-Figure-2.jpg
>>> That's where I found it. and it calls out "9010 complex". (shrug)
>> Herb,
>> I agree this is an issue, and the low resolution of the NHS nomination documents don't help much.
>> However, if you take a close look at building 9010, you will note the sections are labeled "D", "C", "B". and "A". The VCF museum space is in 9010A.
>> The other three H buildings follow the same format, with the "D" section closest to Monmouth Boulevard.
>> Martin
> Interim fix (until such time as InfoAge addresses this issue):
> http://compdecon.org/wp-content/uploads/2021/08/campus_map.jpg
