[vcf-midatlantic] VCF museum machines in need of TLC
Ethan Dicks
ethan.dicks at gmail.com
Fri Aug 13 18:37:26 UTC 2021
On Fri, Aug 13, 2021 at 2:23 PM Jeffrey Brace via vcf-midatlantic
<vcf-midatlantic at lists.vcfed.org> wrote:
> On Fri, Aug 13, 2021 at 2:09 PM Ethan Dicks via vcf-midatlantic <
> > On Thu, Aug 12, 2021 at 9:00 PM Jeffrey Brace via vcf-midatlantic
> > > apparently some disks have the SCA virus.
> > Wow! That takes me back to 1987!
> Yes. I actually got excited when Dennis called to say that the computer had
> a virus! He didn’t know which one, but I guessed the right one. I was
> excited because it is a “historical” virus since it is the first known for
> the Amiga. I just don’t know how to trigger it again to take a picture.
Like a lot of (later) Amiga viruses, it triggers when it thinks it has
spread enough. For the SCA Virus, it keeps a count in memory that it
writes out with each new infection and when that hits 15 or so, the
next reboot gives you the message.
It _might_ be triggerable by (re)booting a write-protected infected
floppy. Some would do that because the detection mechanism would fire
when failing to infect a floppy because it was already infected and
couldn't update the count. That might only be true for some of the
later viruses, but it's quick to try. The long way is to
intentionally stage an infection party with a stack of clean disks by
reboot, swap, reboot cycles until you get the screen.
https://www.vht-dk.dk/amiga/desc/txt/sca.htm
-ethan
