[vcf-midatlantic] VCF museum machines in need of TLC
dave.g4ugm at gmail.com dave.g4ugm at gmail.com
Fri Aug 13 20:04:33 UTC 2021
> -----Original Message-----
> From: vcf-midatlantic <vcf-midatlantic-bounces at lists.vcfed.org> On Behalf
> Of Jeffrey Brace via vcf-midatlantic
> Sent: 13 August 2021 19:19
> To: vcf-midatlantic <vcf-midatlantic at lists.vcfed.org>
> Cc: Jeffrey Brace <jeffrey at vcfed.org>
> Subject: Re: [vcf-midatlantic] VCF museum machines in need of TLC
> On Thu, Aug 12, 2021 at 10:08 PM John Heritage via vcf-midatlantic < vcf-
> midatlantic at lists.vcfed.org> wrote:
> > What are you using to demo the 1040ST?
> Right now floppy disk. We don’t have any SD card solution yet, but are
> looking for someone to donate one.
I use a GOTEK with the Flash Floppy software with mine. There is some menu software you can load on the GoTek that lets you browse a collection of diskette images and then boot the ST from the floppy image.
It is an old GoTek. Not sure if the menu software works with the new GoTek as they use a different chip.  If you need a donation to buy one let me know.
G4UGM
