[vcf-midatlantic] Heathkit H8
Glenn Roberts glenn.f.roberts at gmail.com
Fri Feb 5 14:12:07 UTC 2021
If there are any Heathkit aficionados in the VCF group that aren't aware of "SEBHC" it's the so-called Society of Eight-Bit Heathkit Computerists, which currently collaborates via a google group:
https://groups.google.com/g/sebhc
pretty strong signal-to-noise ratio on this list, with typically a handful of messages a day.  Mostly 8-bit platforms, mainly H8 and H89 but the occasional discussion of Z100, H11 (LSI-11), ET-3400 or HERO.  Many former employees of Heathkit or associated small companies are on the list; also a lot of previous DEC folks. The group maintains several archival repositories of software and documentation and is active in producing modern updates and enhancements to these classic systems (see especially http://koyado.com/Heathkit/Welcome.html).
New SEBHCers welcome...
- Glenn
> -----Original Message-----
> From: vcf-midatlantic <vcf-midatlantic-bounces at lists.vcfed.org> On Behalf
> Of Herb Johnson via vcf-midatlantic
> Sent: Thursday, January 28, 2021 6:42 PM
> To: vcf-midatlantic <vcf-midatlantic at lists.vcfed.org>
> Cc: Herb Johnson <hjohnson at retrotechnology.info>
> Subject: Re: [vcf-midatlantic] Heathkit H8
> It's good to see H8 activity. I have one but it's sitting quiet these days:
> https://www.retrotechnology.com/herbs_stuff/h8.html
> It is also "native" pretty much. I'd not mind a floppy controller upgrade, but
> not too modern a board. I also have some early SEBHC H8 boards unbuilt,
> from quite awhile ago. Thanks for the reminder!
> regards, Herb
> Herbert R. Johnson, New Jersey in the USA
> http://www.retrotechnology.com OR .net preserve, recover, restore 1970's
> computing
> email: hjohnson AT retrotechnology DOT com or try later herbjohnson AT
> comcast DOT net
