[vcf-midatlantic] SX GBIC fiber cable speed
Martin Flynn
maflynn at theflynn.org
Wed Feb 17 01:58:35 UTC 2021
+1
CDL is running a CISCO 4900M as the core, with OM3 10GB links to the
edge switches that are physically in building 9059. The links to the
other buildings will be single mode 1310nm fiber due to length.
And to avoid mix and match, it's all CISCO optics and modules....
Martin Flynn
On 2/16/2021 11:08 AM, MikeWillegal wrote:
> Neil,
> Unless you need the speed or connectivity, I would prefer messing with copper.
> Just too many strange incompatibilities with optical SFPs and various vendors equipment when you go optical. Things that should work, don’t, and visa versa. Wasn’t that terrible in our lab at work, because we had loads of different SFPs, cables and switches to change out to try to get things working, but at home, that sort of experimenting will most likely cost you money. At work, it mostly cost us time, and it was just part of the cost of doing business. After a while, it became a pretty routine thing for us to swap SFPs or switch ports when optical links didn’t come up when connecting new gear.
> When Service Providers do deployments of new equipment, they trial every component in the system before rollout for a reason.
> Just my two cents…
> Mike Willegal
