[vcf-midatlantic] Personal IRIS PSU repair
Joseph Marlin j.marlin at outlook.com
Wed Feb 17 21:21:25 UTC 2021
> Have you found a schematic diagram for it?
> Mike Rosen
Did a lot of searching and came up with bupkis
>   The Indigo2 power supplies fail from 4 certain caps that go bad. Not
> sure about the Personal IRIS machines but tons of vintage electronics
> suffer problems from them and it's usually a general first check.
Yeah, probably something I should just do anyway.
There's a very fun spot where there are four caps soldered directly into two rails of sheet metal that I don't particularly look forward to dealing with...
Thanks for the info, on the Indigo 2!
________________________________
Sent: Wednesday, February 17, 2021 4:07 PM
To: Joseph Marlin via vcf-midatlantic <vcf-midatlantic at lists.vcfed.org>
Cc: Joseph Marlin <j.marlin at outlook.com>
Subject: Re: [vcf-midatlantic] Personal IRIS PSU repair
Hello,
   Step #1, replace all the electrolytic capacitors. They dry up over time.
105c Nichicon or Panasonic from a source like Digikey, Mouser, AVNet,
Newark is top of the line. Can go with cheaper 85c caps from the same
sources. eBay and Amazon might be fakes.
   A low rent want to test them is warm it all up with a hair dryer and
sometimes they will start to work, but that isn't a given just a hack.
                       - Ethan
> Hey, all.
> Just thought I'd reach out and bother everyone to see if there's anyone else out there who's dealt with a dead Personal IRIS PSU.
> Apparently they pretty much all go eventually, but I haven't been able to find anything about what the common failure modes are.
> Hoping there's someone with some thoughts or experience, because I'm massively a novice when it comes to power supply diagnosis.
