[vcf-midatlantic] Greenbar print
Jameel Akari
jakari at bithose.com
Sun Feb 28 02:01:44 UTC 2021
I also got mine working. The foam that keeps the print head flex cables from binding turned to goo along with all the sound absorbing foam. This was making the print head stick on the leftward pass and the stepper controller detected the jam and shut down. I am impressed.
I’m crudely re-inking the ribbon now. It’ll have to soak overnight but I think it’ll come together tomorrow morning.
I think I mentioned the DECwriter serial since I know at least some had RS232. The number of dongles needed to interface that from your laptop is ever increasing these days. Might as well have USB-C to current loop at this point! :)
Jameel Akari
> On Feb 27, 2021, at 7:23 PM, Dean Notarnicola via vcf-midatlantic <vcf-midatlantic at lists.vcfed.org> wrote:
> Proprinter lives! Just need to see if I can reliably get tractor feed
> through it And reconstitute the ribbon
>> On Sat, Feb 27, 2021 at 6:17 PM Andrew Diller via vcf-midatlantic <
>> Connecting printers isn't the hard part. The hard part is getting the
>> files from the Internet to the machine you managed to connect to the
>> printer :)
>> Bill's idea of the Decwriter and using a serial printer (rather than
>> parallel) was a great idea, of course I came up without my whole bag and so
>> I had no USB-C -> USB-> Serial adapter in order to print from the Mac right
>> to the DW. I'll test this out next week as it sounds like a good thing to
>> be able to do in a pinch.
>> -andy
>>> On Feb 27, 2021, at 2:02 PM, Jeffrey Brace via vcf-midatlantic <
>>> On Sat, Feb 27, 2021 at 1:58 PM Dave McGuire via vcf-midatlantic <
>>>> On February 27, 2021 1:05:19 PM Jeffrey Brace via vcf-midatlantic <
>>>>>> Maybe someone near the museum can look for the two DECwriter III's
>> that
>>>>>> might still be around the warehouse, or some other wide carriage
>> printer
>>>>>> there. If you put a new ribbon on one of those and attach to an old
>> pc
>>>>>> running word perfect paginated to 132 character lines you could at
>> least
>>>>>> try to print this at infoage. I bet there is some green bar in the
>>>>>> warehouse
>>>>> Unfortunately there isn't anyone near the museum who has the technical
>>>>> knowledge to do this. We certainly have the paper and the machines, but
>>>> not
>>>>> the technical knowledge to setup, troubleshoot and print it.
>>>> Huh?? Jeff, I'm willing to bet that pretty much everyone here has been
>>>> connecting printers to computers for decades. This is not hard!
>>> There are only a handful of people near InfoAge me (7 minutes away, Tony
>> 17
>>> minutes away, Corey 35 minutes away). I can tell you that my knowledge of
>>> connecting greenbar printers is nil. Don't know about Tony or Corey. We
>>> don't know what kind of printers are in the warehouse. We don't know the
>>> condition of those printers. We don't know which computers that they hook
>>> up to. We don't know if those computers are working. So therefore there
>> is
>>> little chance that we have the knowledge of someone close by, a good
>> known
>>> and working printer and how to connect, etc.
>>> If this was next weekend, then we would have 10 to 15 people from 1 hour
>>> plus driving distance and *they* would certainly be able to figure out,
>>> troubleshoot, connect, etc.
>>> == Jeff
>>>> -Dave
>>>> Dave McGuire, AK4HZ
>>>> New Kensington, PA
