[vcf-midatlantic] Amiga 2000 Getting files onto floppy disk
Alexander Jacocks jjacocks at gmail.com
Sat Jan 2 03:36:32 UTC 2021
You can also use a Gotek USB floppy emulator as an Amiga floppy drive:
https://www.retro32.com/gaming/amiga/01042020508-amiga-gotek-getting-started-guide-installation-set-up-and-game-downloads-flashfloppy
I have one of those in my A600. You can also install it in an external
drive chassis, to share with multiple Amigas, if you want.
- Alex
On Fri, Jan 1, 2021 at 21:04 Ethan O'Toole via vcf-midatlantic <
> https://www.amigalove.com/viewtopic.php?t=15
> Command line transdisk can copy over file
> On Fri, 1 Jan 2021, Sentrytv via vcf-midatlantic wrote:
>    [NON-Text Body part not included]
