[vcf-midatlantic] Museum Report 2021-01-01
Jeffrey Brace jeffrey at vcfed.org
Sat Jan 2 16:07:05 UTC 2021
On Sat, Jan 2, 2021 at 1:13 AM Dean Notarnicola via vcf-midatlantic <
> SD card solution. Damn autocorrect
I turned off autocorrect a long time ago. I think it is the work of Satan
> On Sat, Jan 2, 2021 at 1:11 AM Dean Notarnicola <dnotarnicola at gmail.com>
> wrote:
> > The Satandisk is an Sorry, driving solution for the ST line.
> > The FujiNet probably needs external power to be stable.
> > On Sat, Jan 2, 2021 at 1:06 AM Jeff Salzman via vcf-midatlantic <
> >> You need a proper RGB monitor for the 1040ST to get color at those
> higher
> >> resolutions. Perhaps we can find a low resolution demo that will work
> on a
> >> composite TV monitor output.
> >> On Fri, Jan 1, 2021 at 11:18 PM Jeffrey Brace via vcf-midatlantic <
> >> > Recorded some videos for the docents on how to run demos on the CoCo
> 3,
> >> > Atari 1040ST, Amiga 1000.
> >> > There seems to be a booting problem for the Osbourne, so maybe someone
> >> can
> >> > take a look at it during the repair workshop.
> >> > Also the Atari 1040ST demos seem to be in Black and White, I have no
> >> idea.
> >> > (Thinking out loud, is there an SD card solution for the 1040ST?)
> >> > I'm still having problems with the FujiNet even with the latest
> firmware
> >> > update from a few days ago. I go to run a program and it resets.
> >> > Jeff Brace
> >> > Vice President & Board Member
> >> > Vintage Computer Festival East Show-runner
> >> > Vintage Computer Federation is a 501c3 charity
> >> > http://www.vcfed.org/
> >> > cell: 732-759-1783
Jeff Brace
cell: 732-759-1783
