[vcf-midatlantic] portable terminal preferences
Neil Cherry
ncherry at linuxha.com
Mon Jan 4 03:43:28 UTC 2021
On 1/3/21 10:01 PM, Jameel Akari via vcf-midatlantic wrote:
> Bringing us to USB-to-RS232 dongles, on which I’ll have to disagree, or at least say that your mileage may vary considerably. If
> you find one that works fine for you, it really opens up your options.
I have to agree with Herb on this one. I have friends who work on Railroad equipment
that needs RS232C (supports +/- 25V). We've seen a lot of equipment that doesn't work
well with USB adapters because they can't source the current. I do think the good
PL-xxxx RS232C dongle work but the lesser ones fail miserable. If you drop a line
driver in between it then works.
On the issue of USB 1.1 (whose packet can handle 8 bytes) and serially connected devices:
my friends and I have seen a problem with hand shaking skid (signal wait and sender
skids to a stop). We've seen where changing the inter-character delays can help with
this. Also the new line delays.
That doesn't mean it can't work but you've got to know that there is a problem and
were to look. I use a cheap ch340 USB TTl dongle and I have to cut a line at a time
to paste to the device (115k).
As far as a portable device, I use a chromebook as my serial terminal.
Linux Home Automation Neil Cherry ncherry at linuxha.com
http://www.linuxha.com/ Main site
http://linuxha.blogspot.com/ My HA Blog
Author of: Linux Smart Homes For Dummies
