[vcf-midatlantic] Laserdisk transfer to digital?
David Ryskalczyk
david.rysk at gmail.com
Sun Jun 20 20:49:49 UTC 2021
> There is a device available called the Domesday Duplicator that would allow
> you to capture the video from Laserdiscs at the best possible quality for
> archiving the contents.
This really is the way to go — it captures the signal directly from the disc, which is then processed using the open-source ld-decode software. This allows for some fairly advanced recovery, including dropout correction/repair. As the software is improved over time, the captured data can be reprocessed, resulting in improved conversions. One downside, though, is that each capture can take as much as 40-80GB per disc.
Unfortunately, setting up a capture environment is not the most straightforward —among other things, it is necessary to calibrate the LD player using a GGV1069 calibration disc. I'm not sure these are still available, but as of 6 months ago or so they were from Donberg Electronics and PacParts.
More detailed information on this process can be found at https://www.domesday86.com/?page_id=978 <https://www.domesday86.com/?page_id=978> and assistance can be obtained at the project Discord which is linked from https://www.domesday86.com/?page_id=416 <https://www.domesday86.com/?page_id=416>. If the quantity of discs does not justify setting up a capture environment and VCF is willing to mail the discs to a project member for capture, it might be possible to arrange for this as well — they are very much interested in getting non-movie LaserDisc titles captured.
David
> On Jun 20, 2021, at 4:29 PM, Jeffrey Brace via vcf-midatlantic <vcf-midatlantic at lists.vcfed.org> wrote:
> On Sun, Jun 20, 2021 at 4:23 PM Jeff Salzman via vcf-midatlantic <
>> I have a laserdisc player, time base corrector, and video capture card. How
>> soon does this need done?
> There is no rush for this, but I would like someone to work on it steadily
> so that it doesn't get forgotten.
> A player was donated, but don't know if it works or if it is better or
> worse than your player. I will leave that up to you.
> Alex Jaccocks has offered to do this, but maybe both of you can figure out
> between you two who wants to do it or collaborate.
>> Jeff Salzman
>> On Sun, Jun 20, 2021, 3:23 PM Dean Notarnicola via vcf-midatlantic <
>>> So called “Video Game Enhancers” are simple time-base correctors and will
>>> remove Macrovision.
>>> On Sun, Jun 20, 2021 at 3:07 PM Wil Birkmaier via vcf-midatlantic <
>>>> Laserdisc has a few different formats: all analogue, analogue video
>> with
>>>> mono analogue audio and digital audio, or analogue video with all
>> digital
>>>> audio.
>>>> They key to a good capture these days is to get the best composite
>> video
>>>> converter you can find as the video is stored like a vinyl record, as
>> an
>>>> analogue composite video stream. So yes using the svideo on some of the
>>>> newer players, the conversion of composite to svideo is still not the
>>> best.
>>>> I need to find a link to a decent converter to 720p I have been using
>>> with
>>>> vhs and am happy with.
>>>> On Jun 20, 2021 14:45, Jeffrey Brace via vcf-midatlantic <
>>>> Does anyone know if it is possible to transfer laserdisks to a modern
>>>> digital format? There are 16 laserdisks recently donated that have C
>>>> programming training from 1984, which was part of a UNIX and C
>>>> training program. The reason for the transfer is that we don't know how
>>>> rare these disks are nor how long laserdisk will last.
>>>> There are 16 laserdisks as well as supplemental floppy disks and some
>>>> paper
>>>> manuals.
>>>> Jeff Brace
>>>> Vice President & Board Member
>>>> Vintage Computer Festival East Show-runner
>>>> Vintage Computer Federation is a 501c3 charity
>>>> http://www.vcfed.org/
>>>> jeffrey at vcfed.org
