[vcf-midatlantic] Laserdisk transfer to digital?
Jonathan Gevaryahu
jgevaryahu at gmail.com
Tue Jun 22 21:48:13 UTC 2021
The Domesday Duplicator technology is pretty much brand new, and
captures the raw RF pickup from the laserdisc head directly. Speaking to
preservation groups, the quality-of-preservation bar for these sort of
laserdisc captures is much higher than it was even 10 years ago.
The raw capture from a Domesday Duplicator also is an exact copy of the
disc as read including every frame and vblank field, so if future
improvements are made on the decoding software, this can be re-run
against the captured disc image to improve the resulting quality. A
done-once format conversion from a laserdisc player to a capture device
(even with TBC applied by said device) doesn't allow reprocessing later
without re-imaging the disc once again.
Anything which involves format conversion/re-encoding rather than raw
capture will end up degrading the final result. Things like TBC can be
done in software, in post.
On 6/21/2021 3:50 PM, Dave McGuire via vcf-midatlantic wrote:
> Frequently this is not the case, though, and it's not the case here. Matt is a professional video archivist; he wrote the book on this.
> -Dave
> On June 21, 2021 3:45:45 PM Sentrytv via vcf-midatlantic <vcf-midatlantic at lists.vcfed.org> wrote:
>> Re: [vcf-midatlantic] Laserdisk transfer to digital?
>> From: Sentrytv sentrytv at yahoo.com
>> Date: Jun 21, 3:45 PM
>> To: vcf-midatlantic vcf-midatlantic at lists.vcfed.org
>> As usual, there is a complicated answer and way to do things
>> and
>> there is a simple answer and way to do things.
>> Somewhere in between is the correct way to do this.
>> JM2C
>> Sent from:
>> My extremely complicated, hand held electronic device.
>>> On Jun 21, 2021, at 1:03 PM, Alexander Jacocks via vcf-midatlantic <vcf-midatlantic at lists.vcfed.org> wrote:
>>> Since Matt has offered, and he has the expertise, I think that we should
>>> have him do it.
>>> If you want, at the Baltimore workshop, bring the LDs and, and I will bring
>>> them to Matt, in Pittsburgh.
>>> - Alex
>>>> On Sun, Jun 20, 2021 at 4:30 PM Jeffrey Brace via vcf-midatlantic <
>>>> On Sun, Jun 20, 2021 at 4:23 PM Jeff Salzman via vcf-midatlantic <
>>>>> I have a laserdisc player, time base corrector, and video capture card.
>>>> How
>>>>> soon does this need done?
>>>> There is no rush for this, but I would like someone to work on it steadily
>>>> so that it doesn't get forgotten.
>>>> A player was donated, but don't know if it works or if it is better or
>>>> worse than your player. I will leave that up to you.
>>>> Alex Jaccocks has offered to do this, but maybe both of you can figure out
>>>> between you two who wants to do it or collaborate.
>>>>> Jeff Salzman
>>>>> On Sun, Jun 20, 2021, 3:23 PM Dean Notarnicola via vcf-midatlantic <
>>>>>> So called “Video Game Enhancers” are simple time-base correctors and
>>>> will
>>>>>> remove Macrovision.
>>>>>> On Sun, Jun 20, 2021 at 3:07 PM Wil Birkmaier via vcf-midatlantic <
>>>>>>> Laserdisc has a few different formats: all analogue, analogue video
>>>>> with
>>>>>>> mono analogue audio and digital audio, or analogue video with all
>>>>> digital
>>>>>>> audio.
>>>>>>> They key to a good capture these days is to get the best composite
>>>>> video
>>>>>>> converter you can find as the video is stored like a vinyl record, as
>>>>> an
>>>>>>> analogue composite video stream. So yes using the svideo on some of
>>>> the
>>>>>>> newer players, the conversion of composite to svideo is still not the
>>>>>> best.
>>>>>>> I need to find a link to a decent converter to 720p I have been using
>>>>>> with
>>>>>>> vhs and am happy with.
>>>>>>> On Jun 20, 2021 14:45, Jeffrey Brace via vcf-midatlantic <
>>>>>>> Does anyone know if it is possible to transfer laserdisks to a modern
>>>>>>> digital format? There are 16 laserdisks recently donated that have C
>>>>>>> programming training from 1984, which was part of a UNIX and C
>>>>>>> training program. The reason for the transfer is that we don't know
>>>> how
>>>>>>> rare these disks are nor how long laserdisk will last.
>>>>>>> There are 16 laserdisks as well as supplemental floppy disks and some
>>>>>>> paper
>>>>>>> manuals.
>>>>>>> Jeff Brace
>>>>>>> Vice President & Board Member
>>>>>>> Vintage Computer Festival East Show-runner
>>>>>>> Vintage Computer Federation is a 501c3 charity
>>>>>>> http://www.vcfed.org/
>>>>>>> jeffrey at vcfed.org
> Dave McGuire, AK4HZ
> New Kensington, PA
Jonathan Gevaryahu
jgevaryahu at hotmail.com
