[vcf-midatlantic] OT - 120v to 240v step up recommendations
Chris Fala
chrisjpf33 at gmail.com
Sun May 2 20:06:16 UTC 2021
Exactly!
On Sun, May 2, 2021 at 3:10 PM Ian Primus via vcf-midatlantic <
> I see a lot of very complicated explanations and responses, and a lot
> of very technical "what-if's" attempting to consider every single
> angle. After all, electronics is the passion of many, myself included.
> But at the end of the day, it's a power supply. For a home computer.
> It's been designed to work with ordinary household power - it's not
> going to be super picky about tiny differences in voltage, and
> basically nothing in this entire realm is going to have a problem with
> a difference in frequency. That really only affects AC synchronous
> motors like in a record player or something.
> A step-up transformer is more than sufficient, just get one that's
> beefy enough to handle whatever you intend to run. Being that this is
> an Amiga, it doesn't exactly pull a ton of power, so nearly anything
> should be fine.
> I have a whole bunch of equipment from foreign countries. For
> operating 240v hardware, I have a couple of step up transformers. One
> is simply the isolation transformer scavenged from an old arcade
> machine - one that had multiple input taps. I'm using it backwards,
> restrapped as 240v, operating it as a step-up. No idea what the
> wattage is, but it was meant to power an arcade monitor, so probably
> around 100W or so. Ish. It works fine, I've powered lots of British,
> Soviet, and other European machines on this thing,
> Another step-up I use is actually a travel converter meant to be used
> as a step-down, to power 120V stuff overseas, converting 240V to 120V.
> It's an autotransformer, so it does not isolate in any way, and this
> is likely how most transformers you see on Amazon are built, because
> it's cheaper. I've rewired it backwards so it converts the 120V up to
> 240V. This also works just fine and I've powered lots of foreign
> equipment off of it.
> Nearly every product on Amazon has some "scary reviews" thanks to
> people that simply don't know how to use it. My favorite being from
> some lithium batteries, two different people complained they caused
> their devices to catch fire and nearly burn down their house, with
> photo evidence. One of these photos shows the batteries, burnt and
> swollen, in the compartment of the device. One of which is installed
> backwards. So, huh. You take two 10,000mah batteries, and short them
> out with each other by installing one battery backwards in a device
> that uses two batteries in parallel, and it catches fire? Who knew?
> Silly physics. What will it think of next? It should have *known* what
> this user intended the batteries to do, and not allowed them to
> explode like that. So, yes. You have to take reviews with a grain of
> salt. While people may have had horrible experiences, there is a
> reasonable chance these experiences were self inflicted.
> And yes - precise US line voltage is technically 117V, and I'm pretty
> sure the UK is technically 230V, etc, etc. But the line voltage will
> vary from area to area, and sag during periods of high usage and on
> circuits that are heavily loaded. Any device designed for use in the
> home will be tolerant of these sorts of voltage drifts, and the
> voltage regulation in the power supply of any given home computer, TV
> set, or piece of stereo equipment will be able to handle a reasonable
> amount of deviation.
> In the end, it really doesn't matter - close enough is close enough -
> 220, 221, whatever it takes. It's fine. Any given step-up transformer
> should have no problem powering an Amiga, and any reasonably designed
> power supply is going to work just fine on either 50 or 60hz, and
> within any reasonable deviation of it's intended input voltage. Power
> in houses is FAR from perfect.
> -Ian
> On Sun, May 2, 2021 at 8:56 AM John Heritage via vcf-midatlantic
> <vcf-midatlantic at lists.vcfed.org> wrote:
> > Ok so you recommend just getting a step up transformer and be done with
> it ?
> > Any brands you recommend that are UL or similar? (Or anyone else
> > recommend?) . The models on amazon almost all seem to have at least a
> > percentage of very scary reviews..
> > On Sun, May 2, 2021, 8:03 AM <dave.g4ugm at gmail.com> wrote:
> > > John,
> > > I like to keep equipment original so would not be tempted to mess. In
> > > addition is the new supply accurate. I run my NTSC CoCo off a
> transformer
> > > and its fine.
> > > The AC does permeate a little past the transformer, so the diodes and
> > > smoothing capacitor will usually see 100Hz or 120Hz ripple. (a full
> wave
> > > bridge rectifier acts as a frequency doubler.)
> > > In theory there could be components tuned to this frequency, but even
> so
> > > they would usually not have a high enough “Q” for you to notice or to
> > > affect the operation.
> > > Dave
> > > *From:* John Heritage <john.heritage at gmail.com>
> > > *Sent:* 02 May 2021 12:14
> > > *To:* dave.g4ugm at gmail.com
> > > *Cc:* vcf-midatlantic <vcf-midatlantic at lists.vcfed.org>; W2HX <
> > > w2hx at w2hx.com>
> > > *Subject:* Re: [vcf-midatlantic] OT - 120v to 240v step up
> recommendations
> > > Thanks Dave, Dave, and everyone - I reality do appreciate the comments
> > > and thoughts.
> > > The computer in question is the Commodore Amiga 500 (Rev 5A / NTSC)
> and is
> > > definitely working fine with my other (120VAC at 60Hz to DC output) power
> > > supply. So I'm assuming the only 'risk' item here for 60 hz input
> would
> > > be the (AC to DC) power supply created by the engineer and not
> anything on
> > > the computer itself.
> > > In this case I'm planning to run here in the US (= 60 hz AC) so worst
> case
> > > it would be a '50 hz transformer running at 60hz'.
> > > Does the frequency of the mains carry over to the DC side somehow?
> One
> > > other option the guy mentioned was wiring a 12V/5A DC power supply
> directly
> > > to the DC to DC converter within the new Amiga power supply, bypassing
> the
> > > AC to DC conversion. This would have the benefit of being a smaller,
> more
> > > power efficient (less conversions) and slightly cheaper solution.
> > > Thanks!
> > > On Sun, May 2, 2021 at 4:38 AM <dave.g4ugm at gmail.com> wrote:
> > > Even if the grid frequency is "not used for anything" it can still
> matter.
> > > Some older, larger computers used resonant transformers and these
> simply
> > > won't work.
> > > Going from the UK/EU 50Hz world to the US 60Hz world is not usually a
> > > problem. In general transformers are slightly more efficient at 60hz.
> > > Going the other way can be a problem and US transformers can run warm
> and
> > > over heat.
> > > Dave
> > > G4UGM
> > > > -----Original Message-----
> > > > From: vcf-midatlantic <vcf-midatlantic-bounces at lists.vcfed.org> On
> > > Behalf
> > > > Of John Heritage via vcf-midatlantic
> > > > Sent: 02 May 2021 00:45
> > > > To: W2HX <w2hx at w2hx.com>
> > > > Cc: John Heritage <john.heritage at gmail.com>; vcf-midatlantic <vcf-
> > > > Subject: Re: [vcf-midatlantic] OT - 120v to 240v step up
> recommendations
> > > > Per the guy who designed it (iComp.De - he makes tons of
> > > > amiga/commodore custom electronics) - the input frequency doesn't
> matter:
> > > > does 60 hz / 240V power vs 50 hz / 240V power matter for this power
> > > supply
> > > > if I go the transformer route?
> > > > It shouldn't - it's a simple rectifier design where grid frequency is
> > > not used for
> > > > anything.
> > > > On Wed, Apr 28, 2021 at 8:13 PM W2HX <w2hx at w2hx.com> wrote:
> > > > > Are you sure the PS in the amiga is expecting 60 Hertz power? It
> might
> > > > > be expecting 50 Hz depending on where it is from. This is a bigger
> > > > > problem that a transformer won't solve
> > > > > Behalf Of John Heritage via vcf-midatlantic
> > > > > Sent: Wednesday, April 28, 2021 4:57 PM
> > > > > To: Ethan O'Toole <telmnstr at 757.org>
> > > > > Cc: John Heritage <john.heritage at gmail.com>; John Heritage via
> > > > > recommendations
> > > > > Yep - that's exactly what i'm looking for advice on -- I think
> > > > > transformers are pretty standard/minimalist, but just looking for
> some
> > > > > links or models of 'ready to use' step up transformers that will
> plug
> > > > > into my US 120V outlet and give me a 240V UK or EU style plug
> output..
> > > > > thanks!
> > > > > On Wed, Apr 28, 2021 at 4:49 PM Ethan O'Toole <telmnstr at 757.org>
> > > wrote:
> > > > > > > Hey folks
> > > > > > > I have a new Amiga PSU coming on from icomp that is 240V only.
> > > > > > > I'm
> > > > > > looking
> > > > > > > for recommendations for a 120 to 240V step up transformer rated
> > > > > > > for at least 100W (so it doesnt have to work hard). Preferably
> > > silent.
> > > > > Etc.
> > > > > > > Also what should I avoid in this space ?
> > > > > > I mean you can get a transformer that will take 110 and put out
> 220
> > > > > > before the Amiga PSU.
> > > > > > The Amiga runs on voltages that you could find on any ATX power
> > > supply.
> > > > > > You could make a cable that would go from the funky square DIN
> to a
> > > > > > PC motherboard ATX connector and use any old ATX Flex PSU.
> > > > > > - Ethan
