[vcf-midatlantic] Needed SD card solutions for museum
Jeff Galinat
jgalinat at gmail.com
Fri May 7 20:54:41 UTC 2021
Hi,
While I might be wrong, I remember having a conversation with Alex Bodnar
a few years ago about the H-89 in which he told me both hard &
soft-sectored controllers were available for it. We were discussing it
because I had obtained an H-89 conversion kit for the H-19 terminal & I
thought my only floppy option involved hard-sectored media. You may want
to check with Alex as he is extremely knowledgeable about the Heathkit
systems. Unfortunately, I don't have an email address at hand for him.
Regards,
Jeff
On Fri, May 7, 2021, 1:29 PM Jeff Salzman via vcf-midatlantic <
> As long as the Gotek works with the H89 controller, which required floppy
> drives that support hard sectored indexing.
> On Fri, May 7, 2021, 4:15 PM Dean Notarnicola <dnotarnicola at gmail.com>
> wrote:
> > A gotek should work just fine
