[vcf-midatlantic] Needed SD card solutions for museum
Glenn Roberts glenn.f.roberts at gmail.com
Sat May 8 01:36:17 UTC 2021
There is a read-only firmware for the GOTek on Heath hard sectored.  We have instructions. Contact me off list for more info.  With soft sectored controller board you can have full access via gotek.
> -----Original Message-----
> From: vcf-midatlantic <vcf-midatlantic-bounces at lists.vcfed.org> On Behalf
> Of Jeff Salzman via vcf-midatlantic
> Sent: Friday, May 07, 2021 4:29 PM
> To: Dean Notarnicola <dnotarnicola at gmail.com>
> Cc: jsalzman at gmail.com; vcf-midatlantic <vcf-midatlantic at lists.vcfed.org>
> Subject: Re: [vcf-midatlantic] Needed SD card solutions for museum
> As long as the Gotek works with the H89 controller, which required floppy
> drives that support hard sectored indexing.
> On Fri, May 7, 2021, 4:15 PM Dean Notarnicola <dnotarnicola at gmail.com>
> wrote:
> > A gotek should work just fine
