[vcf-midatlantic] Mac IIci, dead after power on
David Riley fraveydank at gmail.com
Mon May 10 20:26:59 UTC 2021
That's actually annoyingly common with some IIci/IIcx/Q700 supplies. There's (IIRC) a bad cap issue with the trickle standby supply that's not terrible to fix, though you might do better just looking up a new PSU. I think I gave my working one away to VCF folks when I moved in a big box o' busted IIci parts.
If you can't find the fix procedure online, let me know, I can try to see if I have it bookmarked.
- Dave
> On May 10, 2021, at 12:21 PM, Ethan O'Toole via vcf-midatlantic <vcf-midatlantic at lists.vcfed.org> wrote:
> Working on IIci I picked up at swap meet. Ex-Cisco, it's gonna be sweet.
> I read that the battery doesn't matter. Pulled it. Zero leakage.
> Pre-recap, no life.
> Post-recap, no life. (Re-capped machine.)
> 5v 500ma line is fine from the PSU
> 12v line is fine from the PSU
> 5v line is fine from the PSU
> Not sure about -12, but probably just audio?
> No power on chime.
> Screen is black, monitor wakes up. Haven't used the DB-15 to VGA 6 switch converter in ages but it worked last time.
> Powers on from keyboard or rear panel switch.
> I guess the first things to check are the CPU reset circuit and the clock.
> Any other pointers from Mac geeks?
> Recapped the A1200 motherboard I picked up and it booted! Now trying to decide on keyboard options.
> 		- Ethan
