[vcf-midatlantic] Value of Air Compressor in CDL workshop
Martin Flynn maflynn at theflynn.org
Mon May 10 22:01:48 UTC 2021
Sounds like there is enough value to move forward with accepting it.
For now, the plan is a flexible hose with enough length to reach the
middle of the classroom, and out the furnace room exterior doors.  Might
run a manifold via the attic later on,  but that about it as far a
distribution goes...
Power connection is a Hubbell 560P9W pin & sleeve connector - not
planning to hardwire it to prevent ownership confusion.
On 5/10/2021 5:21 PM, Sentrytv wrote:
>   I was able to find a 140 psi craftsman horizontal 30 gallon motor on tank compressor in nice shape, at an estate sale, for $150.
> I use it all the time for blowing off circuit boards, to powering air tool for working on my car.
> Definitely a required tool for any shop.
> One thing for certain, that if you don’t have enough reserve on your tank and pressure on your line it’s going cause a lot of PSI problems when you run lines throughout different buildings or rooms.
