[vcf-midatlantic] Bernoulli Drives needed in working condition
Dave McGuire
mcguire at neurotica.com
Tue May 18 15:14:08 UTC 2021
Again if memory serves, and I'm pretty sure it does in this case, the
three or four different ISA controller cards with DC37 connectors are
interchangeable, i.e. the on-disk format is not dependent upon which
card you use.
-Dave
On 5/18/21 11:02 AM, Jeff Salzman via vcf-midatlantic wrote:
> The donation came with the original documentation and driver disk for the
> card. It just didn't have the ISA card. If we can find the same card on
> eBay, then we should be good with the driver. It's also unknown if the
> driver disk is readable. Should be trivial to fire up the IBM PC in the
> museum and do a DIR to assess its contents in the meantime.
> On Tue, May 18, 2021 at 10:57 AM Dave McGuire via vcf-midatlantic <
> vcf-midatlantic at lists.vcfed.org> wrote:
>> ISA Bernoulli controllers are pretty common. I'm sure I have a few
>> but I don't know that I could find them quickly enough to be useful
>> here. But they hit eBay with some frequency. You'll need the DOS
>> driver for that board too.
Dave McGuire, AK4HZ
New Kensington, PA
