[vcf-midatlantic] Which Amigas support 1.44MB/1.76MB floppy drives?
jsalzman at gmail.com
Wed May 19 20:56:20 UTC 2021
To run a HD floppy drive for 1.76MB storage on anything but an Amiga 4000,
you'll need appropriate hardware or mods. A company called Applied
Engineering made an external drive that worked that way for all Amiga
computers.
The Chinon FZ357A drive is the only HD floppy drive that could conceivably
work on all Amigas without mods due to its ability to run at the slower DD
floppy drive speed. The Amiga chips can't keep up with the speed of a
conventional HD floppy drive. I also think you need KS 3.1, too.
Jeff Salzman
On Wed, May 19, 2021, 2:55 PM Sentrytv <sentrytv at yahoo.com> wrote:
> Just a thought.
> I picked up some floppy Drives from Kelly at the swap meet that are on the
> list for amiga compatibility.
> Did not give it a thought as to if the motherboard is compatible On my
> A2000?
> Mike Rosen
> Sent from:
> My extremely complicated, hand held electronic device.
> > On May 19, 2021, at 10:32 AM, Jeff Salzman via vcf-midatlantic <
> vcf-midatlantic at lists.vcfed.org> wrote:
> > The Amiga 4000 does. There's a jumper on the motherboard to switch
> between
> > DD or HD drive, depending on what's installed in the system.
> > I'm not sure about the Amiga 3000, but the other systems do not
> > (inherently) support 1.44MB/1.76MB drives.
> > Jeff Salzman
> >> On Wed, May 19, 2021, 10:04 AM John Heritage via vcf-midatlantic <
> >> Hey there -
> >> I was just curious which Amigas (and KS/WB versions) support 1.44/1.76MB
> >> floppy drives?
> >> I have an HxC emulator that can support 1.76MB ADF files, and I know
> some
> >> later Amigas can support this format, but it doesn't work on my Amiga
> 500,
> >> at least when booted to KS/WB 2.0 or 3.1. I believe the floppy
> controller
> >> on the Amiga is part of Paula, so what else changed that allowed this
> >> format to work? Would a stock 1200?
> >> Thanks!
> >> John
