[vcf-midatlantic] Which Amigas support 1.44MB/1.76MB floppy drives?
murph
murphnj at murph.info
Wed May 19 21:19:23 UTC 2021
----- Original message -----
From: Jeff Salzman via vcf-midatlantic <vcf-midatlantic at lists.vcfed.org>
To: vcf-midatlantic <vcf-midatlantic at lists.vcfed.org>
Cc: jsalzman at gmail.com
Subject: Re: [vcf-midatlantic] Which Amigas support 1.44MB/1.76MB floppy drives?
Date: Wednesday, May 19, 2021 16:56
To run a HD floppy drive for 1.76MB storage on anything but an Amiga 4000,
you'll need appropriate hardware or mods. A company called Applied
Engineering made an external drive that worked that way for all Amiga
computers.
The Chinon FZ357A drive is the only HD floppy drive that could conceivably
work on all Amigas without mods due to its ability to run at the slower DD
floppy drive speed. The Amiga chips can't keep up with the speed of a
conventional HD floppy drive. I also think you need KS 3.1, too.
That sounds familiar, I do recall having to pick up a very particular model to make it work. (Mine is internal)
