[vcf-midatlantic] [OT] My eyes are aging - glasses recos for electronics work/small print reading?
Dean Notarnicola dean.notarnicola at vcfed.org
Tue Nov 16 20:20:30 UTC 2021
Yes, I’m nearsighted and I formally carried around cheap drugstore reading
glasses for when I had contacts in.  I now use multi-focal lenses and no
longer need the readers.
On Tue, Nov 16, 2021 at 3:16 PM John Heritage via vcf-midatlantic <
> I'm sure at least a few of you can relate.  Hell, I *know* Crawford
> Griffith can relate ;-)..
> I wear contact lenses and without the lenses I can read small print/see
> tiny text on PCBs without problem.  Once the contacts are in I have real
> trouble focusing in some cases on small fonts, or other details such as the
> crappy way manufacturers print specs on power supplies.
> Any specific recommendations for eye glasses here?  Are cheap reading
> glasses sufficient for [seeing] soldering "up close" and other uses like
> that or is there a type of reading / magnifying glass that's also for
> safety that someone would recommend?
> Thanks!
> John
