[vcf-midatlantic] OT - Projector upgrade to 9059 classroom
madodel madodel at mac.com
Sat Nov 20 17:46:29 UTC 2021
On 11/20/21 10:32, Martin Flynn via vcf-midatlantic wrote:
> CDL received a Mitsubishi  FL7000U projector as a donation.  Also have
> the Chief Ceiling Mount, and all of the signal cables + two spare lamps
> Plan is to deploy it in the 9059 Classroom, however we need a 16:9 ratio
> screen screen as it won't work well with the existing 4:3 Radio screen,
> Before making one from scratch, is anyone aware of a 16:9 screen around
> 150" x 84"  that we can press into service?
> Link:
> https://www.mitsubishielectric.com.au/Mitsubishi_FL7000U_1080P_LCD_Installation_Projector.html
> Martin
I see 180" 16:9 screens on Amazon for under $100 which are close to the
dimensions you are looking for but these are wall mount. Dimensions are
156.8" x 88.2". It doesn't come with a frame, just hooks to mount to the
wall. But you could build a frame for it and attach using the grommet holes
in the fabric. There are more expensive options with a stand frame but not
sure how sturdy they would be and if this is for permanent wall mounting it
might be better to build your own frame.  Would that work?
https://smile.amazon.com/Projector-Screen-Upgraded-180-inch/dp/B07Q7ZP9SQ I
would think something like this material would be a better viewing screen
than something self made. Largest rollup screen I have dealt with was a
120" and over time the rollup mechanism failed.
Mark
