[vcf-midatlantic] OT - Projector upgrade to 9059 classroom
Martin Flynn maflynn at theflynn.org
Tue Nov 23 23:40:28 UTC 2021
Quick Update:   In order to have everything in place for VCF East, we
(CDL) made a decision on direction
We purchased 2 x 2 box steel tubing and corners to support screen
fabric, and initially plan to use screen bungees to stretch it out.
Short term this is what we went with for the screen itself:
https://www.amazon.com/NIERBO-Double-Layer-Projector-Screen/dp/B08JYRRMF6
All of the parts came to less then $400,and gives us an option to
upgrade the screen fabric to professional grade should it not fit
everyone's needs.
On 11/20/2021 10:32 AM, Martin Flynn wrote:
> CDL received a Mitsubishi  FL7000U projector as a donation.  Also have
> the Chief Ceiling Mount, and all of the signal cables + two spare lamps
> Plan is to deploy it in the 9059 Classroom, however we need a 16:9
> ratio screen screen as it won't work well with the existing 4:3 Radio
> screen,
> Before making one from scratch, is anyone aware of a 16:9 screen
> around 150" x 84"  that we can press into service?
> Link:
> https://www.mitsubishielectric.com.au/Mitsubishi_FL7000U_1080P_LCD_Installation_Projector.html
> Martin
