[vcf-midatlantic] VersaWriter
Ethan O'Toole
telmnstr at 757.org
Mon Oct 4 14:46:37 UTC 2021
I have never heard of this thing. Things to note I see from the manual.
The software looks like it uses Joystick port 4 on the 800, so you might
need to change that to 2 to use on a XE or XL.
Also, has Herb mentioned it's probably two pots, and the Atari has the
paddle controllers. Try running that software with a pair of paddles
plugged in, good chance it would go?
If they're popular someone should replicate em.
