[vcf-midatlantic] Apple IIgs to Duodisk cables
Brian Marstella
brian at marstella.net
Fri Aug 12 17:40:12 UTC 2022
Over the years I've purchased 2 of them from
https://iec.net/product/apple-duo-drive-cable-3/
You might see if this is the same that you need.
Brian
On Fri, Aug 12, 2022 at 1:31 PM Sentrytv via vcf-midatlantic <
> From experience with an apple II, the cables are expensive.
> But can be made, if you have the connectors and cable, yourself.
> I do not have spares but just wanted to let you know they can be found.
> Mike
> Sent from:
> My extremely complicated, hand held electronic device.
> > On Aug 12, 2022, at 1:22 PM, Bob Shuster via vcf-midatlantic <
> > Before I go crazy trying to find these online, does anyone have some
> spares, or can recommend a source? I have two Duodisk units that I want to
> connect to an Apple IIgs, so that’s DB-19 to DB-25 F/F. (And I guess this
> would also work with my Apple II computers as well.) Ultimately I’ll just
> turn these around and include the cables with the Duodisks.
> > - Bob Shuster
