[vcf-midatlantic] Help! I cant get asciiexpress to work with my II Plus
Dan FitzGerald danjfitzgerald at comcast.net
Fri Aug 12 21:10:28 UTC 2022
Bart,
Yes, I have tried that as well.  No dice :-(
I'm not sure why I should be getting any errors doing this stuff.  Is
Apple II tape stuff finicky?
Regards,
Dan FitzGerald
They/Them/Theirs
http://www.vm.ibm.com/devpages/dfitzger
-----Original Message-----
From: Bart Hirst via vcf-midatlantic <vcf-midatlantic at lists.vcfed.org>
Reply-To: vcf-midatlantic <vcf-midatlantic at lists.vcfed.org>
Cc: Bart Hirst <louisbhirst at gmail.com>
Subject: Re: [vcf-midatlantic] Help! I cant get asciiexpress to work
with my II Plus
Date: Fri, 12 Aug 2022 15:55:09 -0400
Did you try both the HIFI & 8KFI versions?  For some reason I had to
use
8KFI to create disks because HIFI wouldn't work (checksum error.)  I'm
using an Apple][e & Pixel3a with an inexpensive audio cable.
On Fri, Aug 12, 2022 at 3:40 PM Dan FitzGerald via vcf-midatlantic <
> I have an Apple II Plus, and have been been having limited success in
> trying to get asciiexpress.net to work with it.  I can successfully
> load _some_ games (Dig-Dug and Montezuma's Revenge), but I cannot get
> the vast majority of game titles to load.  And I have been having
> zero
> luck getting the disk image downloads to work; usually, it will start
> the self-extractor app and then give me a checksum error before
> failing.  I had heard somewhere that interference from other cables
> could be the culprit and that using a Monster aux cable had good
> results, so I picked one up.  No luck, unfortunately.
> Has anybody else experienced similar problems, and if so, how did you
> resolve them?
> Regards,
> Dan FitzGerald
> They/Them/Theirs
