[vcf-midatlantic] FS: AIM-65, $1 starting bid
Chris Fala chrisjpf33 at gmail.com
Tue Aug 16 20:12:39 UTC 2022
Thanks for sharing, I'll be bidding!
On Tue, Aug 16, 2022 at 4:05 PM Jonathan Chapman via vcf-midatlantic <
> All,
> Finally got an AIM-65 I've been meaning to sell wrapped up and listed:
> https://www.ebay.com/itm/275425213541
> This one was used in some industrial control application and had custom
> ROMs in it when I received it. It was also missing the plastic display
> mounting blocks, so a friend of mine measured his and 3D printed
> replacements. The displays were gone through and a number of bad ones
> replaced. The main board had to be basically entirely resocketed. The flex
> cables to the display board were of course crumbling, so they were replaced
> with two new Nomex jumpers.
> The printer works but has two columns which are light. I don't know if
> that's just that the paper I had that fit it was ancient (out of my HP 5150
> thermal printer, which I don't have working yet) or if the printer is weak
> in those two columns.
> Thanks,
> Jonathan
