[vcf-midatlantic] RAM Test/Diagnostic ROM for Rockwell AIM-65
Douglas Crawford
touchetek at gmail.com
Fri Aug 19 16:08:12 UTC 2022
Oh dang.. that makes an AIM project a lot more viable.
A good starting point to bring one up & maintain.
Oh Jonathan, you trouble maker...
On 8/19/2022 11:52 AM, Dave via vcf-midatlantic wrote:
> Nice one Jonathan!
> This will come in handy.
> Dave
> Jonathan Chapman via vcf-midatlantic wrote on 8/19/22 8:08 AM:
>> All,
>> Finally got some time to clean up the source for our RAM
>> test/diagnostic ROM for the AIM-65:
>> https://github.com/glitchwrks/aim65_memtest/
>> Initial work was largely done by TangentDelta. This was written to
>> help diagnose and repair some dead AIM-65s. The test will run on a
>> minimally functional AIM-65 -- all you need is a working CPU, ROM
>> socket, and display board. It performs the following tests:
>> * ROM checksum
>> * Stack page quick write presence
>> * Zero page quick write presence
>> * RIOT single-pass memory test
>> * Full system memory test
>> The ROM checksum and stack page tests are accomplished with macros so
>> that they can run with no RAM, since of course that might be faulty!
>> Once the stack page passes, zero page is tested. With stack and ZP
>> tested, the RIOT and exhaustive system memory tests are performed.
>> These tests are more complete, since we have a minimally functional
>> system by this point. The exhaustive test is based heavily on the
>> routines from the OSI MEMORY TEST from OS-65D 2.0, published in OSI
>> Small Systems Journal, Volume 1, Number 3, September 1977.
>> Thanks,
>> Jonathan
