[vcf-midatlantic] Can anyone identify this mystery IC
Dave McGuire mcguire at neurotica.com
Sun Aug 21 15:27:53 UTC 2022
   I would say quad or hex, rather than dual.  You can see it by finding
those six sets of transistors, three on each side, each with the same
sets of leads brought out to pins.  Hex inverter, a-la 7404 but mil-spec?
   I agree that the asymmetrical package is very unusual.
   The density is so low that we should be able to suss out its function
given a bit of study.  Already the Vdd/Vss pins are identifiable at the
center top and bottom.
            -Dave
On 8/21/22 11:23, Douglas Crawford via vcf-midatlantic wrote:
> A little more...  https://imgur.com/f4noWuk
> We have this on display under a microscope at VCF Mid-Atlantic museum.
> It is strangely constructed to my eye.
> no lead frame or bond wires.
> Its build ON the leadframe.
> Its symmetrical, appears to be a dual something.
> A mixed signal IC design collegue said:
> That lead-frame is really weird.
> It seems to be some sort of flip-chip, but the leads don’t even line up
> from one side of the chip to the other!
> Never seen anything like it.
> The only other thing I would GUESS is that this is some sort of analog
> IC, probably bipolar.
Dave McGuire, AK4HZ
New Kensington, PA
