[vcf-midatlantic] Can anyone identify this mystery IC
Douglas Crawford touchetek at gmail.com
Sun Aug 21 16:39:36 UTC 2022
These are the transistors?
https://imgur.com/aLpqVpE
I got one additional response from another designer:
"Looks like some kind of gate array with only the metalization layer
being clearly visible. I worked on alot of these in the late 70's. I
have no explanation for the bonding pad structures."
On 8/21/2022 11:27 AM, Dave McGuire via vcf-midatlantic wrote:
>    I would say quad or hex, rather than dual.  You can see it by finding
> those six sets of transistors, three on each side, each with the same
> sets of leads brought out to pins.  Hex inverter, a-la 7404 but mil-spec?
>    I agree that the asymmetrical package is very unusual.
>    The density is so low that we should be able to suss out its function
> given a bit of study.  Already the Vdd/Vss pins are identifiable at the
> center top and bottom.
>             -Dave
> On 8/21/22 11:23, Douglas Crawford via vcf-midatlantic wrote:
>> A little more...  https://imgur.com/f4noWuk
>> We have this on display under a microscope at VCF Mid-Atlantic museum.
>> It is strangely constructed to my eye.
>> no lead frame or bond wires.
>> Its build ON the leadframe.
>> Its symmetrical, appears to be a dual something.
>> A mixed signal IC design collegue said:
>> That lead-frame is really weird.
>> It seems to be some sort of flip-chip, but the leads don’t even line
>> up from one side of the chip to the other!
>> Never seen anything like it.
>> The only other thing I would GUESS is that this is some sort of analog
>> IC, probably bipolar.
