[vcf-midatlantic] Can anyone identify this mystery IC
Douglas Crawford touchetek at gmail.com
Sun Aug 21 19:35:19 UTC 2022
They are changing their tune, Dave :)
One says:
" Metalization is hiding all the lower levels. Looks like a device with
just 6 transistors."
Another responds:
"So it would be a *transistor* array, not a gate array then.
If so, then I’m confused as to why it would need so many pins if there
are only 6 transistors.  Unless it was a prototyping part where all the
transistors were individually made accessible."
(I'm positing with them # pins is because possibly they're gates)
On 8/21/2022 12:50 PM, Dave McGuire via vcf-midatlantic wrote:
>    Yes, but we should be able to determine everything, or almost
> everything we need to know from that layer.  We'd need better and
> higher-resolution photos.
>               -Dave
> On 8/21/22 12:48, Douglas Crawford via vcf-midatlantic wrote:
>> Ah, now we are getting somewhere.
>> We can only guess then, from the remaining metalization layer
>> correct?  Educated guess?
>> On 8/21/2022 12:43 PM, Dave McGuire via vcf-midatlantic wrote:
>>> On 8/21/22 12:39, Douglas Crawford via vcf-midatlantic wrote:
>>>> These are the transistors?
>>>> https://imgur.com/aLpqVpE
>>>    I'd need to look more closely, but those appear to be clusters of
>>> transistors, six of them.  They are likely gates.
>>>> I got one additional response from another designer:
>>>> "Looks like some kind of gate array with only the metalization layer
>>>> being clearly visible. I worked on alot of these in the late 70's. I
>>>> have no explanation for the bonding pad structures."
>>>    Agreed; this has either had its passivation layer removed, or it
>>> had never been applied.  I suspect the latter, as it would've been
>>> removed with acid, and there isn't so much as a trace of debris from
>>> that.
>>>              -Dave
