[vcf-midatlantic] Can anyone identify this mystery IC
Dave McGuire mcguire at neurotica.com
Sun Aug 21 21:32:28 UTC 2022
On 8/21/22 17:07, Douglas Crawford via vcf-midatlantic wrote:
> Ah, so the red lines are not b/c/e?
> That's what I was first thinking.
> Here me trying to make some sense of it
> https://i.imgur.com/gOZujMR.jpg
> Red lines inputs?
> Could the blue things be capacitors?
   I do not think they're capacitors.  Remember, this is an IC; think
three-dimensionally.  All we can see from that picture is the upper
metallization layer, where connections to silicon are made.  There are
several layers below that.
> Maybe purple outputs?
>  From this view... OR gates?
   Possible.
> At least I have some agreement now that several learned eyes
> see transistors. It might be enough for our purposes
> to just have a good guess of how many transistors there
> are, and be able to identify them.  What they are doing
> is a less important detail for our purposes at this
> point in the exhibit.
   Yes, there are definitely transistors there.
> So how many do to think you see in each group?
> We may never know for sure, but I'll probably run with
> your number as an estimate.
   Well, as I said, we'd need a higher-resolution image with better
lighting.  We need to be able to see a layer or two below that.  I'm
guessing there are two or three.
               -Dave
Dave McGuire, AK4HZ
New Kensington, PA
