[vcf-midatlantic] Can anyone identify this mystery IC
Sentrytv
sentrytv at yahoo.com
Sun Aug 21 21:41:49 UTC 2022
Pattern indicates 2 dimensional thinking.
Sent from:
My extremely complicated, hand held electronic device.
> On Aug 21, 2022, at 5:32 PM, Dave McGuire via vcf-midatlantic <vcf-midatlantic at lists.vcfed.org> wrote:
> On 8/21/22 17:07, Douglas Crawford via vcf-midatlantic wrote:
>> Ah, so the red lines are not b/c/e?
>> That's what I was first thinking.
>> Here me trying to make some sense of it
>> https://i.imgur.com/gOZujMR.jpg
>> Red lines inputs?
>> Could the blue things be capacitors?
> I do not think they're capacitors. Remember, this is an IC; think three-dimensionally. All we can see from that picture is the upper metallization layer, where connections to silicon are made. There are several layers below that.
>> Maybe purple outputs?
>> From this view... OR gates?
> Possible.
>> At least I have some agreement now that several learned eyes
>> see transistors. It might be enough for our purposes
>> to just have a good guess of how many transistors there
>> are, and be able to identify them. What they are doing
>> is a less important detail for our purposes at this
>> point in the exhibit.
> Yes, there are definitely transistors there.
>> So how many do to think you see in each group?
>> We may never know for sure, but I'll probably run with
>> your number as an estimate.
> Well, as I said, we'd need a higher-resolution image with better lighting. We need to be able to see a layer or two below that. I'm guessing there are two or three.
> -Dave
> Dave McGuire, AK4HZ
> New Kensington, PA
