[vcf-midatlantic] Can anyone identify this mystery IC - Who can do die photographs here ?!
Douglas Crawford touchetek at gmail.com
Wed Aug 24 05:56:08 UTC 2022
Mystery allegedly solved.  New testimony from Corey says this
was a Bell Labs demonstration vehicle.
Not necessarily intended to ever be a real IC.
On 8/21/2022 6:43 PM, Dave McGuire via vcf-midatlantic wrote:
>    I can image the die.
>           -Dave
> On 8/21/22 18:11, Douglas Crawford via vcf-midatlantic wrote:
>> Perfect. 2 or 3 is a close enough for now.
>> That's 12 to 18 transistors, estimated range.
>> Calling for someone that can image a die!
>> Thanks Dave.
>> On 8/21/2022 5:32 PM, Dave McGuire via vcf-midatlantic wrote:
>>> On 8/21/22 17:07, Douglas Crawford via vcf-midatlantic wrote:
>>>> Ah, so the red lines are not b/c/e?
>>>> That's what I was first thinking.
>>>> Here me trying to make some sense of it
>>>> https://i.imgur.com/gOZujMR.jpg
>>>> Red lines inputs?
>>>> Could the blue things be capacitors?
>>>    I do not think they're capacitors.  Remember, this is an IC; think
>>> three-dimensionally.  All we can see from that picture is the upper
>>> metallization layer, where connections to silicon are made.  There
>>> are several layers below that.
>>>> Maybe purple outputs?
>>>>  From this view... OR gates?
>>>    Possible.
>>>> At least I have some agreement now that several learned eyes
>>>> see transistors. It might be enough for our purposes
>>>> to just have a good guess of how many transistors there
>>>> are, and be able to identify them.  What they are doing
>>>> is a less important detail for our purposes at this
>>>> point in the exhibit.
>>>    Yes, there are definitely transistors there.
>>>> So how many do to think you see in each group?
>>>> We may never know for sure, but I'll probably run with
>>>> your number as an estimate.
>>>    Well, as I said, we'd need a higher-resolution image with better
>>> lighting.  We need to be able to see a layer or two below that.  I'm
>>> guessing there are two or three.
>>>                -Dave
