[vcf-midatlantic] Just slightly OT...
Ian Litchfield kd2ixl at gmail.com
Fri Aug 26 11:38:43 UTC 2022
Martin,
Glitchwrks actually sells them premade
https://www.ebay.com/itm/274503108836?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=IdP5hzZ1QGu&sssrc=2349624&ssuid=4wYR4sbZTle&var=&widget_ver=artemis&media=COPY
The 12887 chip should be functionally identical to the 14287. However I
would reach out just to be sure.
I picked one of these up not too long ago to to fix a pentium board. I am
going to be at the workshop and can bring the chip to test in your machine
if you would like?
 I’ll be available Saturday and Sunday.
Ian L.
On Fri, Aug 26, 2022 at 7:29 AM Martin Flynn via vcf-midatlantic <
> CDL has a piece of telecom hardware that has a failed clock chip (same
> part as may early computers)
> Failed chip is a  DS14287.  It's suggested replacement is a
> BQ4287MT-SB2.   Both are NLA
> Rather than grind the chip open and piggyback a battery on it, has
> anyone built one of these https://github.com/necroware/nwX287 as a
> replacement? https://www.youtube.com/watch?v=svPNxILeQEw
> Martin
