[vcf-midatlantic] [OffTopic] - Anderson SB120 to XT60 Female custom cable?
John Heritage john.heritage at gmail.com
Sun Aug 28 01:10:26 UTC 2022
Hey folks,
I'm not exceptionally good at soldering and crimping, and was wondering if
anyone knew where I could buy custom ready-made cables like the subject
here?
I have an Ecoflow Delta mini battery, which accepts up to 300W via an XT60
female connector..  While this is normally intended for solar input - any
source will do including batteries.  (The charge controller specifies
11-75V range, 10A max up to 300W)
I also have a Ryobi riding mower which supplies power via 4 x Lead Acid
batteries in series (48V), and they output power via an Anderson SB120
connector.
I'd like to have the extra capacity for an emergency and looking for
recommendations on where to find or ask for a custom cable build like this.
Thanks!
John
