[vcf-midatlantic] ?Comcast at Home? internet speeds 1998 or so?
MikeWillegal mike at willegal.net
Wed Feb 2 15:30:11 UTC 2022
I don’t think that Comcast is using DOCSIS for this high speed service as the 2 Gbps lab speed I mentioned is really only barely achievable in a dedicated lab environment and it needs to use of a ton of spectrum that is normally reserved for their video feeds.  Comcast is using direct fiber connections for their really high speed services and I’m guessing that you would have to pay plenty for it.
regards,
Mike Willegal
> On Feb 2, 2022, at 8:27 AM, Neil Cherry <ncherry at linuxha.com> wrote:
> On 2/2/22 08:05, Mike Willegal via vcf-midatlantic wrote:
>> things have changed a lot- a few years ago  I was able to demonstrate about 2Gbps upstream in a lab environment to a single
>> mode with DOCSIS 3.1 technology
> Comcast is selling 3/3 Gbps in the business space and I hear that consumer will be able to get
> 3/something soon (not 3/3).
> Ob old man rhetoric: I remember when I was a kid you'd buy a DS0 and split into 9.6 with
> a Paradyne 740 mux and you were happy (if you could get it to work). ;-)
> PPS: I'm working with 400Gbs Ethernet that we bundle (400x8). The times they are a changing ...
> I started out with wet/dry loop (28.8 baud - AP wire service).
> Linux Home Automation         Neil Cherry       ncherry at linuxha.com
> http://www.linuxha.com/                         Main site
> http://linuxha.blogspot.com/                    My HA Blog
> Author of:    	Linux Smart Homes For Dummies
