[vcf-midatlantic] ?Comcast at Home? internet speeds 1998 or so?
Christian Liendo cliendo at gmail.com
Wed Feb 2 15:40:37 UTC 2022
It is probably rate limited 10G or what they call fractional.
I have multiple 10Gbps circuits at work and we were offered fractional.
They all seem to do the same thing. They run some SMF and put a box on
your site that they manage to do the rate limiting.
On Wed, Feb 2, 2022 at 10:32 AM MikeWillegal via vcf-midatlantic
<vcf-midatlantic at lists.vcfed.org> wrote:
> I don’t think that Comcast is using DOCSIS for this high speed service as the 2 Gbps lab speed I mentioned is really only barely achievable in a dedicated lab environment and it needs to use of a ton of spectrum that is normally reserved for their video feeds.  Comcast is using direct fiber connections for their really high speed services and I’m guessing that you would have to pay plenty for it.
> regards,
> Mike Willegal
