[vcf-midatlantic] Seeking Apple II Plus DOS System Master Disk
Ethan O'Toole
telmnstr at 757.org
Tue Feb 8 16:36:22 UTC 2022
If you have a serial card, you can use the ADT software. Apple Disk
Transfer. It's magic.
Run the java software on PC/Mac/Linux, type command that redirects serial
to rom monitor. It types out the bootstrap code. Then it can transfer disk
images from modern system straight to floppy. This way you need no
floppies on your Apple II to make a boot disk for your Apple II.
- Ethan
On Tue, 8 Feb 2022, Anthony Scarola via vcf-midatlantic wrote:
> Hello Everyone,
> I'm working to test out my new Apple II Plus and in need of a DOS System
> Master Disk. I can find them on eBay but thought I'd try the group first.
> Thank you,
> Anthony Scarola
> 757-418-0082
> anthony at scarolas.com
