[vcf-midatlantic] Seeking Apple II Plus DOS System Master Disk
Bill Degnan billdegnan at gmail.com
Tue Feb 8 23:00:01 UTC 2022
If you're near Kennett Square, PA you're welcome to make your own boot disk
for an Apple //, III, MAC, etc. using the systems, drives and media on hand
there.
Specific to this thread there are a number of working Apple //'s of various
types with drives (5 1/4" 3.5") and at least one emulator cards available
(for sale) as of this writing.  Many versions of DOS on hand.  Check
kennettclassic.com/contact.cfm for hours before your trip, store hours vary
in the winter.  Bring your own disks or purchase new or NOS 5 1/4", low
density 3.5, HD 3.5 disks.  The service is free, disks and hardware are not.
Bill
On Tue, Feb 8, 2022 at 11:40 AM Ethan O'Toole via vcf-midatlantic <
> If you have a serial card, you can use the ADT software. Apple Disk
> Transfer. It's magic.
> Run the java software on PC/Mac/Linux, type command that redirects serial
> to rom monitor. It types out the bootstrap code. Then it can transfer disk
> images from modern system straight to floppy. This way you need no
> floppies on your Apple II to make a boot disk for your Apple II.
>                         - Ethan
> On Tue, 8 Feb 2022, Anthony Scarola via vcf-midatlantic wrote:
> > Hello Everyone,
> > I'm working to test out my new Apple II Plus and in need of a DOS System
> > Master Disk. I can find them on eBay but thought I'd try the group first.
> > Thank you,
> > Anthony Scarola
> > 757-418-0082
> > anthony at scarolas.com
